Hello,
We had to install a sub-panel for a restaurant rennovation,
work included adding some ten 20A outlets for additional equipment
An electrician did all the work, and I tested all the outlets
which seem to work fine
(i am due for inspection)
having some geeky background I looked at the open sub-panel,
it only has 3 wire service two-hots and a neutral (and no ground)
Upon further inspection, I see that the electrician has run the
green GROUND wire directly from main panel to new outlets,
and the hot/neutral from sub-panel.
Questions:
1) is this code compliant?
2) is this standard practice?
I understand that the ground and neutral at the sub-panel should not be bonded but having no ground at the sub-panel has me confused
Thank you
Questions:
Thank you
