wondervamp
- SF Bay Area
- Shop technician
Hello, this is my first post to this forum. I am a union apprentice. I am installing a new sub panel in a cottage behind the main house. This cottage has it's own main panel outside in the front of the main residence about 60 feet from the cottage. Whoever ran the feeders from the main to the sub panel inside the cottage ran it underground in PVC with no ground wire! It is only being fed with two hots and a neutral.
How do I ground this system? It will be very hard and almost impossible to pull a ground through the existing conduit from the main to the sub panel. There are water pipes and other systems in the ground alongside my electrical raceway. Am I correct in thinking I can drive a ground rod at the cottage and attaching a ground that way?
Please be as specific in details as possible. Also inform if I need to bond the neutral/ground at the sub panel in this case. As I know I should not do that in normal circumstances.
Thank you in advance.
wondervamp
wondervamp
