Older homes were wired without branch circuit grounds in available cable. A rewire is an expensive undertaking and I was wondering if there is some less expensive solution.GFCI outlets replacing the old two prong outlets is the only solution that comes to mind.
The code will only permit a single ground clamped at the incoming copper water line.Incorporation of more than one ground wire locations clamped to the copper water line seems to be a possible solution. Would the ground currents be that prohibitive ?
I can't find any provision in the code that addresses this issue.
