DanZ
Is this part of a package system that has been designed by an engineer that understands the complexities of solar systems, or a home owner bought some equipment at HD* setup?iwire said:OK here is my dumb question of the day.
As some of you know I am doing a grid tied solar installation. For this installation we have a 50 KW 208 volt 3 phase inverter without a neutral.
The service is 208Y/120.
This seems odd to me, I would have assumed the inverter would also have to be 208Y/120.
Is this inverter correct for the application?
If it's a piece meal system, you might be better off having an engineer that's trained in solar systems sign off on it, or at least review it and make recommendations, if it's a kit system, than an engineer has already signed off on it, in theory.
Is this system grounded? That would really be all you need, if you're planning on using the earth ground as a "neutral" path back to source. I hear there are a few countries that use a single line supply system with an earth "neutral", since they have large spans without anyone tapping into them.
*Not to insinuate or insult HD or the homeowner, just used as a reference for a piecemeal system that may or may be right.
