resistance
- WA
Can anyone recommend an underground splice kit for #12AWG--where no torch is required?
mdshunk said:Couple B-Caps filled with RTV silicone and a few wraps of Super 33.
No, not for a permanent repair. If it's a patch job until I can schedule trenching or whatever, I don't waste a splice kit. My way is legal, though.peter d said:Now you have my attention....you really do it that way?
Lxnxjxhx said:That 3m thing is quite a production.
cowboyjwc said:One of the silicon filled wire nuts is listed for direct burial.
ultramegabob said:I know of an electrical contractor that makes underground splices in UF by using wirenuts and pushing them into a paper cup full of silicone, I have followed behind him and made repairs on his repairs....
Funny thing, I used this exact stuff just today to fix some #12 UF that met an excavator. Worked quite well, I'd definitely recommend 3M cold-shrink. My other favorite for temporary repairs is Scotch 130C splicing tape.ultramegabob said:this stuff is pretty neat, I have used it a couple times, It is pre-stretched oversized, with a plastic coil core, as you pull and uncoil it the rubber closes up on the wire really tight...
http://solutions.3m.com/wps/portal/..._RJH9U5230GE3E02LECIE20OUP7_node=P9196N2DQ5be
