- Bremerton, Washington
- Master Electrician
If its a single conductor then a direct bury wire nut - King makes the ones I use. For a cable you must cover the exposed ends of the cable- the 3M Skotch Cast are the best, but slow to put on, heat shrink is OK, you can use hot air gun or torch but not the soldering type the heat will burn the shrink.
