Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
if you buy the special receptacle listed for isolated ground it should have a triangle symbol on it.
Yes your equipment’s ground conductor to the receptacle should be isolated / no connection from the receptacle box and it’s bonding to normal EGC system such as through EMT raceway conduit if used. I only had to run two circuits with an isolated ground once for a laboratory containing a particle analyzer and plasma computer system.
In one of my grounding books it said a non conductive connector could be used to interconnect the raceway and receptacle box, I guess this takes the exemption of having to bond small sections of conduit or equipment only used for the support or protection of wires or devices
