76nemo
- Ogdensburg, NY
wptski said:Mark:
Some torque screwdrivers are ajustable up to 70 in/lbs! What kind of animal can use one to its highest limit?
They must have wrists like that big green guy
wptski said:Mark:
Real men measure their strength in lb/ft.glene77is said:On a weightlifting machine, I measured a one hand twist at 40 lb/in.
LarryFine said:Real men measure their strength in lb/ft.
Now thats hot!!! Whats her name??peter d said:What about a Super Cow?
quogueelectric said:Now thats hot!!! Whats her name??
Well, not 10 in a single pass, but . . .peter d said:I seem to remember that you can drill through 10 2X8 floor joists with a 36 volt cordless drill one handed, and you don't even need a ladder?
Paul, have you ever seen a manufacturer's instruction to not use an anti-oxidant?radiopet said:What the NEC ( 110.14 ) says about it is IF you choose to use it it or where it is used it can't adversely affect the conductors, installation, or equipment.
SmithBuilt said:I have seen cases where I believe Nolox would have prevented connection problems. It certainly prevents the white chalking. I now use it on all the al connections.
On another note it is very good on battery terminals. Clean them good and coat all the exposed lead.
weressl said:Uh-oh, better be careful t is only listed for AC use......
wptski said:I always wanted to ask if anybody uses de-ox/nolox on copper, anybody??
No alox is an oxide inhibitor. Aluminum is a good conductor aluminum oxide is not the No alox is supposed to prevent oxygen from contacting the aluminum that is why you are supposed to put it on before it is brushed because it keeps oxygen from combining with the alluminum to form a poor conductor. I have seen idiot after idiot putting the product on after the connection had been made and this is why aluminum had so many fires is because of untrained monkeys installing it.
