Hey guys, I've been working on a job which really falls a bit in between residential and commerical type construction. I do almost all commerical, so I thought nothing of using a bunch of non-IC rated cans, but I am now getting called to the carpet on the fixture choice. I know if I specified a residential-grade can, the architect and the client probably would not have liked it, and rightly so...it just wouldn't have been up to par (no pun intended :wink: ) with the other really nice fixtures.
But really, I just don't see a lot of commerical-or-higher grade can fixtures which are IC rated. When you run into a situation like this, do you
a) pull the insulation back, knowing it's going to be less efficient
b) build boxes around the cans (I'm not even sure this is an option...the can still needs to be ventilated somehow)
c) I haven't thought of a third option yet
Any ideas would be greatly appreciated.
