kwired
Electron manager
- NE Nebraska
- EC
On a farm though there can be high leg delta systems supplying the farm - three phase is run to structures that need three phase, like a feed mill or grain storage/handling area. If there is a larger water system there may be a three phase well. If there is a house on the property it still normally just gets 120/240 supply run to it but originates at the high leg delta supply and not a separate supply, same for other outbuildings with minimal power requirements.It's a safe bet that it's single phase.
99% of single family residences only get a single phase service here. It takes a lot of money and cajoling to get a utility to run 3 phase out to a residential service, often including you having to pay the full cost for them to run the third wire from the nearest 3 phase connection point, which can be miles away.
