which type of clamp are you talking about?
The ones that you knock out with the end of your t-strippers, or the type that is internal, and uses a set-screw to tighten the clamp.
A quick clip is integral and has been calculated into the cu. in. capacity,clamps are added as needed.Look at bakelite 4 sq`s with side brackets for example.There are four ko`s and 2 screw holes but the cu in cap is listed without these installed
