Along with owning/using a megger comes knowing how to use it, what to disconnect from the circuit being tested, how and why to make resistance tests at low test voltage before performing on a high test voltage reading. The power strip, and pretty much anything plugged into receptacles should be unplugged when testing the premises wiring. ....
You missed my point entirely.
My assertion is that many times nuisance tripping can be caused by transient surges originating from the outside, and then the surge-protected power strip shunts it out. This trips out the AFCI or GFCI device.
So many have said you have to test your circuits, and sometimes that involves using a megger. Fair enough.
But unless you unplug the surge power strip, using a megger is useless. Using a surge power strip downstream from a AFCI or GFCI device can and will cause nuisance tripping. And testing the wiring without removing such items first is a big waste of time.
My discussion with ELA alludes to this condition, one in which he refuses to acknowledge.
I don't believe that any mini-circuitry contained within that tiny breaker can be sufficient to protect the rest of the circuit from transient surges. Internal circuitry, maybe, but not the whole circuit! Besides, things like GFCI receptacles don't seem to have such features, and surge strips plugged into them also cause nuisance tripping.
Just this week, had another customer complain about nuisance tripping of only ONE of his AFCI breakers. He has several, but guess which one has the computer surge-power strip plugged in? You guessed it, the one that is tripping out. Coincidence? Maybe.
But I'd be willing to bet that removal of that surge strip will solve his nuisance tripping problems.
As stated earlier, I won't waste my or my customers' time troubleshooting until such things have been removed and the condition continues to be a problem. Then and only then it may be time to break out the megger ...
