What do you guys think about this literally 120v to ground?
It's on the main lug
Sent from my SM-N920P using Tapatalk
Main lug hot leg
If one probe is on the main hot leg and the other to earth as it appears, I would expect 120v.Main lug hot leg
Is that phantom voltage? Or true voltage?
Main lug hot leg
Agreed.I thought one probe was on the ground. I did not look close enough to see the damaged conduit.
Probes between the main hot leg and the ground will for sure give you a good voltage reading.
Yes they areAre those exposed conductors in the ground?
Main lug hot leg
Where is your PPE?
