- Tennessee NEC:2017
- Semi-Retired Electrician
I received this alert for persons that may have to work in Hurricane affected areas. It is primarily geared towards hurricane damage but can also be helpful for anywhere that might have suffered flooding or water damage.
The link will take you to the article, then you will have to go to a couple of links to get to the PDF file that has info on water damaged equipment.
http://www.nema.org/Technical/Code-...ating-Water-Damaged-Electrical-Equipment.aspx
