Sierrasparky
 - USA
 - Electrician ,contractor
So now that It is 2014 and the AFCI for replacement receptacles is now the law for most code cycles how are you folks out there dealing with this?
We very rarely see outlet replacements here. Homeowner, handyman or electrician on a service call replaces them.
I guess we're going to hope that whoever changes outlets knows the code. We can't police everyone who goes to the big box stores to buy from folks who have no clue.So that is my Question. What do you folks do. Or better stated what are you going to do?
So what if it is not inspected.
when was the last time you did work in a kitchen and had to replace receptacles in a older home that did not have GFCI protection. Did you ignored installing them because you WERE NOT GETTING INSPECTED!
I assure you that when I performed service work, I did it to code. I can sleep at night.:thumbsup:
I no longer perform service work. I'm an inspector. In the event I do anything electrical at my house, I will do it to current codes. I will still sleep at night.:happyyes:So once again when you do service work are you going to install an afci recept when you do have to make a replacement ?
I must say I would not use AFCI receptacles unless forced by inspection. I don't want the call backs.
Then again, both the OP and I are in CA, which is just now going to the 2011 NEC, which I don't believe has the replacement requirement.
Because nobody seems to make them at this time.Why not make it a combination AFCI/GFCI so you could replace a 2 wire receptacle with a 3 wire?
I must be missing something.
