- Bremerton, Washington
- Master Electrician
How many GFCIs have been replaced due to the inspector using a plug in tester on a GFCI with no EGC?
A home inspector told a home seller that they needed a new service because if you added up the numbers on the individual breakers they were more than the main.
FWIW, home inspectors rarely have the 'authority' to demand any work be done. They're simply pointing out issues that can be used for negotiation.
How about this: you tell the buyer sure, no problem I can do a new service. Let me get some prices so I'll know how much to increase the selling price.
-Hal
For a bargain price of only $10k instead of 18I'd rather tell the HO "Sure, I could charge you $18k for a panel upgrade (along with the required updated house wiring)..... however, this HI is flat-out wrong. I can write up a response for you, replete with all the necessary code references and service calculations, toss in my experience and credentials, email it to you as a PDF, and you can use that instead."
For that, I'd probably end up with a lifetime customer.
My house alone would make his head spin on just the 2 pole breakers in the main panel.So this HI is saying a 200A panel can only have 8 20 amp breakers, if he uses the 80% rule. Wonder what he would say to a full 60 space panel or one that is full of tandem breakers? HI should really know what the codes are so home buyers or even sellers do not have to foot a unnecessary bill. I would provide a load cal. to the seller and buyer and show them in the code how you’ve come up with that to put their minds at ease over the false info this HI as given. Would not even bother with showing this to the HI he will lose his business by the reputation he will get by giving out false/dumb info
