Jim W in Tampa
- Tampa Florida
paul said:Solid or stranded?
I will be nice and let you use stranded and head can be 10 feet long LOL
Jim W in Tampa said:Why did you derate from 75 degrees and not the 90 ?
Jim W in Tampa said:It cant be this easy to get out of afci breakers.I see a great market for a 19 amp and 14 amp breaker,but then why would they want to help us when they make more from selling worthless afci breakers.
But 1, 3, 6, and 10 Amp fuses are recognized as standard overcurrent devices, so if the derated current is less than 10 Amps you must use 10 Amp fuses instead of breakers.finhead said:My question is also a thought problem. Section 240.6 does not recognize 10 amp circuit breakers as a standard OCPD.
I was an apprentice on a job where we were pulling 60+ 14's in rigid. They only carried 4-20 mA signals.Jim W in Tampa said:Use # 14 and get even more in it LOL.You make the head and i will put our tugger on it.
roger said:..after using 10 amp breakers you would not have to guard the bedroom circuits with AFCI's.
ramsy said:This original idea deserves other considerations not mentioned yet.
1) If fixed loads over 5A cannot use these outlets, 10 amp circuits may be impractical for many fixed bedroom appliances, which "shall not exceed 50 percent of the branch-circuit ampere rating." a) Fixed cord & plug, heaters, etc. 210.23(A)(2), b) Window AC's 440.62, c) Park Trailers 552.46(B)(3)(a)
ramsy said:2) Vacuum cleaners over 12A may blow 10A breakers, especially if any shared outlets (same circuit) are used by entertainment electronics, lamps, or home office equipment.
ramsy said:3) Are you sure it won't be inspected?
Installing 10A breakers in panels invites inspectors, ignorant to compatible-design considerations, to harass you with red tags requiring costly time and appeals to prove compliance.
LarryFine said:This thread sure took a silly turn.
No, it's mine. :wink:roger said:Is that an experts opinion?:grin:
