1940 NEC Handbook. When current flow, on ground electrode conductors creates 15 volts to earth, on light switch boxes, this is objectionable current. Equipment ground conductors should connect to the ground electrode not the neutral bus.
Current flow causing the earth to dry around the rod is objectionable current.
