erickench
- Brooklyn, NY
Pierre I've already corrected my own error. But what I'm saying now is that a circuit breaker on the supply side of a meter will be able to protect against any short circuit inside the meter enclosure. The new change in the 2008 NEC should cover this. Meter disconnects are now required to interrupt the circuit. I was under the impression that interrupt in this case means opening the circuit whenever a fault occurs. If the hot lead touches the meter enclosure the current will flow downstream first to the service disconnect and then back through the neutral to the utility transformer. The circuit breaker acting as meter disconnect will trip.
