dbuckley
- Canterbury, New Zealand
Also, I'd like to add that I don't see how "multiple neutral to ground" connections is relevant. Though not a good thing I'm having a hard time seeing how it would affect current at a ground rod.
If there are multiple neutral to ground connections (eg one at transformer pad, one at service entrance) then the ground is acting as a parallel conductor to the neutral conductor. if current flows through the neutral, it will also flow through the parallel path - the ground.
