silverromex
I have been red tagged before when I forgot to run a bonding jumper from the meter base enclosure to the service panel. For a 200A residential panel this was done with a #6 copper wire. I recently read where doing so could be a hazard because by the neutral and grounding conductor now being in parallel with each other the unbalanced current flows through both conductors. If the grounded conductor loses its continuity then the grounding conductor would then carry all of the unbalanced (neutral) current. A hazard would then exist if the grounding conductors ampacity is less than the amount of current flowing through it. So why is bonding the two enclosures together a code requirement if doing so creates a possible hazard? Thanks.
