Obsolete Lighting Panel
Little Bill
Tennessee NEC:2017
Semi-Retired Electrician
Does anyone know if Lutron or any other mfg makes dimmer modules and or control boards that will fit in an old discontinued lighting panel?
At least from what I can gather the panel is not made anymore. If the modules can be repaired, that would be fine too. I just wouldn't want to try and fit all the conduit back in a new cabinet.
Here's a picture of the nameplate and a portion of the cabinet. It's all I have now but I could get more pics if needed.
cainisunabel
Houston, TX
Curt has your answer, give Lutron a call. You will need the panel and module information though. Their customer service/help "hotline" is awesome.
Sent from my N861 using Tapatalk
Little Bill
Tennessee NEC:2017
Have you called Lutron?
I sent the facilities manager a link to a PDF from Luton and he said he wanted to call them.
I just thought some of you might know of another brand that might fit this panel in case Lutron doesn't support this anymore.
cainisunabel
Houston, TX
I've run into a couple of items that were out of production. In one case they had the exact product in stock and in others they had new products that worked as direct replacements. I've never heard of a situation where Lutron says you are SOL. They will find a way to help.
