Obstacles to underground conduit run
EC Dan
Florida
E&C Manager
I need to run power to a well via underground conduit, however there are two impediments to this run: a swale and an underground service feeder. The new conduit run will intersect both these are right angles (see below, blue is swale, gray is service feeder, black arrow is proposed circuit). Looking for advice on how to do this safely and effectively.
For the swale portion, it should be shallow enough that the PVC conduit can handle the gentle grade down and up, and the swale is dry this time of year, however it will likely have 1-2 feet of water in normal conditions most of the year. The problems I can see with this are the extra weight of the water and erosion. Could just packing some loose rocks on top of the conduit before re-burying be sufficient, assuming I do the calculations to make sure the conduit can bear the weight?
For the service feeder, I want to stay clear of it. Even though I know 811 will get me approximate location, they won't give me depth. My thought was to pour a concrete slab over the location where the new circuit would intersect the service, and bring the new conduit above ground so it can cross over it that way (see below). Then no safety concerns with digging near service conductors. Not sure about the impact of weight of the concrete on the service though; the concrete wouldn't be structural, so it wouldn't need to be thick.
If anyone has experience dealing with these sorts of obstacles to underground conduit runs, I'd appreciate feedback and suggestions.
Swale is about 5 feet wide, 2 feet deep. It's actually at one of the ends of a network of swales, so filling in this section may be an option. It wouldn't impact water routing. The conduit will be parallel runs of 1.5" PVC, approximately 200 feet.
It is a cable in a HDPE conduit. Art 353. Typical length is 1500' spool. It does require a specific fitting to transition from HDPE to Sch 80 or 40.
Who do you buy it from, a local supplier? I tried to get my hands on some HDPE in the past and my normal suppliers had no stock or experience with it.
Rob G
Seattle
When you get near the service line, get a locator tool for your own use, hand dig as close as you dare. You can do the last bit with a pressure washer and a vacuum cleaner. It is not the best arrangement but cheap and easy. You can hire this done by people with their own vacuum trailer and pressure washers also.
Rob G
Seattle
Here, it's mostly available from suppliers of pivot irrigation. You could try companies that do directional boring. I was getting it directly from a company in Montana, IIRC. The eastern portion of Washington should have it available.
Just hand dig carefully around the existing conduit, find it and either go over or under it. I dont see the swail as being a problem at all. I think you are overthinking this.
Yes you're probably right about me overthinking it (although I always prefer to overthink than underthink!). We will go slow and excavate by hand around the area where the service is, shouldn't be an issue.
Location of the service is what you want to know.
I hit a drop from a transformer. The hole belched steam. The service was only 18" deep.
Ya just never know if someone took a short cut.
