Occupancy sensor for exhaust fan
nickelec
US
What would you fellas reccamend to switch on a small exhaust fan in a commercial bathroom a straight 120v switching relay or a low voltage sensor with a separate relay. What brands and model's are you guys typically using looking for something celling mointed
Sent from my SM-G965U using Tapatalk
I think all RIBs have a horsepower rating, just different amps, contact voltages and coil voltages. I'm a big fan of Functional Devices' product line. Standard RIB U1C should do the trick. I believe you can have either 120-volt or 10-30 volt AC or DC coil signal. The U1C has a rating of 1/3 HP @ 120 volts.
