Kansas Mountain
- Oklahoma, United States
- Lighting and Lighting Control Designs
Looks like I'm late to the response and you're probably headed in another direction at this point. But for future reference:OK so I need some time to study this system but just off the cuff could you tell me if I have the general idea of how this goes together? I'm thinking the sensor just mounts on the wall or ceiling (it's wireless and probably has a battery?) then it talks to a device somewhere in the near vicinity which then sends a command (does it use wi-fi) to the wall mounted switch/dimmer which then dims the lights to whatever the inspector is happy with or just shuts them off, so do I wire the switch like a normal switch, I will have a neutral in the switch box. Thanks
- Yes, the sensors are wireless and are powered by CR 123 battery. The Pico wireless switches use a CR2032 button cell, just like what you'd find your garage door opener. All devices come with a battery already and have a minimum life expectancy of 10 years. Whenever battery placement is required though, they're all non-proprietary and replacements can be picked up from Walmart, drug store, etc. Per your assumption, yes, the switches and sensors can pretty much stick anywhere.
- The Vive Hub (the processor for the system) generates it's own WiFi frequency and communicates with the powpaks, primarily for scheduling and programming purposes. The powpaks receive wireless signal commands from sensors and switches for "manual" operations. Scheduled commands would come straight from the Hub.
- While some switching devices are available in hard-wired versions, mostly you'd want to be using the wireless devices to maximize initial construction cost savings by not having to install switch back boxes, conduit drops, and wiring to switch locations. But even with the wired switch options, you are only providing power to the switch - the communication protocol is still wireless.
