- Placerville, CA, USA
- Retired PV System Designer
That will work just fine too, as long as you wire them to convert a 480 delta to a 240 wye, with corresponding phase shift/vector group.I understand.
So the 416:480 transformer is not a problem, even though uncommon?
And what about using three 240:480 1? xfmrs?
More often they will be wired to convert a 480 delta to a 240 delta, which we do not need here, but either configuration is possible, depending on the result you are trying to achieve.
