Fred B
- Upstate, NY
- Electrician
Have a panel replacent that has supply to a low voltage flood alarm system. Have had to run several AFCI as wiring was extended beyond 6 ft, so was double checking existing circuits for potential shared neutrals. While checking found one very puzzling backfeed. A circuit we'll call #7 and the other we'll call #12. Now #12 has a plug in 120/12V transformer to the flood detector panel. When xfer is plugged in I have continuity to #7 neutral but whe unplugged no continuity. Can plug in other loads into #12 and have no continuity to #7, only one that causes issue is the xfer. Not familiar with this alarm system, or its internal wireing, but it does seem to be tied into the house fire/security alarm system as well, but that is powered from an entirely different panel. Now what could be causing this issue? For now told them not to be plugging in the xfer.
