I am looking at an office complex service entrance design. There will be 16 different offices (tenants) in one bldg and 3 offices in an adjacent bldg. The design calls for an outside pad mount transformer 3ph 120/208 feeding an outside disconnect switch (3ph OCPD). The disconnect would then feed 16 meters. Each meter would feed a 200 amp panel 1ph 120/208. A second lateral service from the transformer would feed another disconnect located on the the 2nd bldg and that disconnect would feed three meters and each meter would feed a 200 amp panel 1ph 120/208 inside the bldg.
1. Is this design allowed based on 230.40 Ex5?
2. Are two transformers needed?
3. Would it be allowed to have two disconnects on the bldg with 16 meters instead of one?
4. How far from the transformer can the disconnects be located?
5. Would the fault calculation be the same for both disconnects?
6. Any suggestions for improvement on this design?
