marissa2
- Connecticut
What about the plastic boxes from Woodhead?
Lou
Lou
When mounted on the wall, it will not be handled in the same fashion, as when it is hanging.
Lou
True but it does not change the fact that the kos can be pushed in and contact a terminal on a device. I've always found it odd that those types of boxes are allowed.
From my experience, in most places that have cord drop type receptacles and wall receptacles, the wall receptacles take a far worse beating than the hanging ones.
When they run the fork lift into the hanging boxes they swing in the wind, the wall mounted boxes do not fair as well.
That doesn't get around the code rule that requires the hub to be a part of the box.One thing I've noticed in a few Home Depot stores with the way they have their cord drops set up is the use of what looks like a custom made drawn 4" box with only about 4 knockouts total on the box (one cenetered on each side). They aren't normal looking steel box knockouts, either. They look like they are a lot harder to break apart because they have four tabs holding them on as opposed to the typical singular. I guess this is their solution to the concern about the knockouts being pushed in.
I dont think using a bell box meets the spirit of the requirement for intergal hub. The bell boxes are cast aluminum (or mystery metal if theyre chinese ones) and I have seen ones used on portable cords that have cracked from being dropped. I prefer the actual pentant boxes like those from ericcson, woodhead, cooper, etc.
Ok. Some of the points here are valid, but I don't read 314.23(H)(1) as prohibiting the use with an approved connector (kellums) it actually it allows for it. The idea that the KOs can be pushed in and short out against the device is true I guess but I thought that is why we ground the box. If we find the KOs bent in a little bit we change out the enclosure or if the device developes a crack we change out the device.
Great point Don. So in the application that I have listed, in your opinion, I could hang a bell box from a kellums strain relief connector and please the authorities having jurisdiction ?
Im not sure our local inspectors are the OSHA inforcers around here but, if the safety guy says it has to then that should be a huge factor.This requirement can be found in OSHA documentation.
I had a project recently where we removed the cords that were hanging 20' from 1900 boxes in the ceiling and installed a receptacle in the box and made up a cord with a male and female end on it. Then we used a vellum grip from the cord to the bar joist formed a small drip loop plugged it into the receptacle. The safety guy was happy.
