I hear you also sell extension cords with 2 male ends! Very hard to find!Originally posted by physis:
That's physisafe.com for replacement fuses and free safey tips.
Yea, I guess you're right. The best repeat customers are the ones that don't die from using your product!Originally posted by physis:
After all, one of our primary interests is an expanding market share.![]()
For a very good reason, and why many Europeans call receptacles "mains." ("Is there a mains connection anywhere around here?")Originally posted by don_resqcapt19:
I understand that the plugs used in the UK have fuses to protect the appliance and the cords.
Don
No, the current always takes all available paths.Since electricity takes the path of least resistance, current will flow to all the connected devices from the shortest direction between the breaker and the load. If a large load (Such as a "cooker," or an air-conditioner) exceeding the capacity of one #12 is connected, current will flow from BOTH directions along the ring.
this is not quite the way it is, for an accurate explanation of the UK ring circuit Click HereOriginally posted by LawnGuyLandSparky:
In Europe, the wiring in many homes and offices is not linear like it is in the U.S. (A string of daisy-chained outlets.) They use a "ring circuit" typically rated at 40 amperes, utilizing only #12 ga. wire. They can do this because each receptacle is tied to the "ring" WITHOUT EVER CUTTING THE WIRE. The circuit "returns" to the 40a breaker.
As Don points out, current will divide and flow in all paths proportionate to the resistance/impedance of the available paths, this will happen with any current regardless of load size.Since electricity takes the path of least resistance, current will flow to all the connected devices from the shortest direction between the breaker and the load. If a large load (Such as a "cooker," or an air-conditioner) exceeding the capacity of one #12 is connected, current will flow from BOTH directions along the ring. .
I have! Very strange fuses! I went to Germany a few years back. Of course I went prepared with digital meter and a few tools to examine their 50Hz system. I was very surprised when I realized it was not 240 volts with 2 ungrounded conductors but 240 volts with just one ungrounded conductor.Originally posted by LawnGuyLandSparky:
Most Euroeans have never seen the inside of their breaker box.
Originally posted by davedottcom:
seems to me it would be allowed to do this with the hot legs but not the neutral side of the circuits.And to me, I have Always thought that (loop) was a great idea. The load would always be "Shared" by 2 wires.
Not equally, but shared. Still sounds like a good idea to me, except twice as many homeruns at the panel!![]()
Would this be a violation here?
Maybe looping the circuit "after" the homerun?
In other words to home run the circuit to outlet #1 then #2 then #3 then #4 then back to #1 again.
Dave
Originally posted by petersonra:
<added>Originally posted by davedottcom:
Dave
Come to think of it, you can't parallel a hot conductor either.
RogerOriginally posted by roger:
LawnGuyLandSparky,
