G
Guest
Guest
I started this conversation under a different thread called "Best Way to Get 'Clean' Power to a Computer Outlet". I want to start a new thread. I got my clean power answer, but now want to move on to the physics of the solution. It involves Ohm's law; electrical engineering; and field experience. I welcome all your input on this. I have read enough about IGR's to know that nobody understands them completely. If you know somebody who does, please have them join this discussion. I have learned a lot in the past two weeks researching this. I am not an apprentice. I have a lot of experience. It's just dated, rusty, and dusty. Let's dust this one off! I have witnessed the magic of an IGR in the field and now I want to understand it's pros and cons.
Here is some reading you might want to do before you offer up any off-the-hip suggestions:
See NEC 250.146(D) and 406.2(D) for the requirements for isolated grounding-type receptacles.
The Basics of Isolated Grounding Receptacles by Mike Holt, Mike Holt Enterprises, Inc., Electrical Construction & Maintenance, Oct 1, 2001
Preventing Isolated Ground Abuse by Bryan Lundgren, P.E., Haworth, Inc., Power Quality, Sep 1, 2002
Code Basics: Article 645, Information Technology Equipment by Mike Holt for EC&M Magazine
Isolated Ground Reference One by Mike Holt
Should I use Isolated Ground for my Sensitive Electronic Equipment?
Responses to "Grounding Sensitive Electronic Equipment"
If you want to do more reading you can do a Search for "Isolated Ground" on the Mike Holt Newsletter Search page:
http://www.mikeholt.com/searchsite.php#
Leviton ProGrade Isolated Ground Receptacles 15A & 20A
HERE IS THE ISSUE I AM CONCERNED WITH:
The computer will be plugged into the IGR. Other devices will be plugged into the IGR, or they will be plugged into another IGR, or they will be plugged into a "standard" receptacle (SR). There will be cables running from the computer to various devices (printer, monitor, mouse, keyboard, speakers, Ethernet, etc.).
QUESTION #1: In an IGR environment what stops an electrical potential from developing in the various devices? The law of physics says the stray current will take any path of least resistance. Kirchhoff's Law & Ohm's Law will prevail.
QUESTION #2: What prevents the cabling between the computer and the devices (i.e.- the printer cable, or the speaker cable) from becoming a current carrying conductor? The laws of physics says the stray current will take any path of least resistance. Is the path of least resistance going to be through the printer or speaker cable? Is this a hazard? Will this defeat the IGR?
I welcome your constructive comments during this time of new beginnings for me. Let me know if you have any other web links to read up on IGR's.
[Note: This post was spellchecked and edited after initial posting. Thanks to charlieb for pointing out a typo: Kirchhoff. Spell Checked in a jiffy with ieSpell ]
[ September 04, 2003, 12:37 PM: Message edited by: awwt ]
