The technician must have known that it would enhance the results if it were possible to overcome the resistance of the outer, dryer layer of the load, thus the need for the addition of the water component. This could reduce the resistance by one or even two orders of magnitude.
It might be noted that the resistance of the load in question is, on average, slightly higher than its companion version as the companion load normally has more of the lower resistivity material that is the main path for current flow.
I would suspect that the load, especially given the high external moisture content, would be almost entirely resistive and the reactance would be two to three orders of magnitude lower than the resistivity, depending on whether the flow was perpendicular or parallel to the fibers of the main current path.
