What are some of the advantages/disadvantages of using oil filled vs dry type transformers in an industrial setting?
I have seen several facilities where the dry type transformers are located inside of the electrical room with the rest of the equipment and have seen others where oil filled transformers were located outside of the room with conduit/busduct going to the equipment inside the room.
So is the decision to use oil filled driven by where the transformer will be located (inside vs outside)? Is the decision to locate transformer outside of room usually for saving space within the room? Obviously if you have them both in the room you can "close couple" them which will be a cheaper installation.
With an Oil filled transformer do you need spill containment and fire barriers even if using FR3 fluid?
Just want to hear others take on the two different applications.
