Re: OK, how would you wire your OWN house?
Lot's of good ideas here. I'm currently building a house and here are a few things I did and a few I would like to do. Some (most?) have already been mentioned.
Did or doing:
15A lighting ckts with 14Wire
15A AFCIs for the bedroom recpts
15A recpts for the general purpose
Fed spec back-wired recpts and switches. Pigtailed instead of pass-through.
Flanged, gasketed boxes on outside walls
5000K florescents in the kitchen and laundry
Florescents in the closets, even the shallow ones - I haven't got the shallow closet switch figured out yet - maybe a motion detector or a door switch.
As few as possible boxes in outside walls. Used floor boxes instead.
Cat5e to the boiler room - future monitoring.
Cat5e and coax to above the front and back doors. I'm thinking cameras some day - if I can ever figure out how to keep them warm enough to work.
50A, 4pole gen connection to a three wire transfer switch - feeds an essential loads panel with: boiler, heat trace for well, well pump, two outside non-gfi recpts for block heaters, and couple of inside lights.
Photocell smoke detectors in garages and laundry.
Electric kickspace heaters in the bathrooms.
Ufer ground - PoCo still made me drive a ground rod (sigh)
3W switch motion detector for the stairwell lgts (don't know how well this is going to work)
UG service in 2" PVC conduit - 36" burial, compacted under and the first 12" over, bedded in 100% passing a 200 screen (the 200 screen is a bit of a joke, it's all silt). PoCo squawked loudly and longly - assured me they would not fix it if it failed during the winter. That's okay; I put it in as reliably as available and I'll deal with the risk. I really don't like overhead services.
Next time additions:
Full length 42 space main panel - that's 42 full size CB's - I've got nothing against half-sized CB's, I just want the full length panel.
Subpanel on an adjoining wall to the kitchen/laundry - the kitchen/laundry is 80% of the house load why not put a panel right next to the big loads?
Heat trace in the foundations drains and eave drains.
Still Looking for:
Voice recognition door locks
Video cameras good to -40 without external heating
Push button timers for the bath fans and kickspace heaters - one ON button gives a programmable on-time, say 20 to 40 minute range, with OFF button.
carl
Having a blast with my evenings and weekends
And I fully realize that if I were doing this for a living, I'd be starving
