JaxELectric
Hey guys, quick question-
Customer called, bought a used O&H Act-4 lathe. The transformer is with the unit an operates @200v. The nameplate says 40kva. Right now it has been dropped off in a temporary storage facility where they would like to test it before pulling down their in use machine that it is replacing. This storage has an empty 100amp panel (3ø 230v). With the 140% I have the oc calculated over 100a . This thing will never see that much amperage I'd bet. I guess my concern is testing it there not knowing the coordination downstream. The storage is in an undustrial mill, same site as the Tooling company, different building though. Any thoughts or help with if we should fire this thing up there? They wont be milling anything, mostly a function check. Thanks!
