Old can light
olly
Berthoud, Colorado
Master Electrician
I have an old can light housing where the wire hooks are in the top of the housing. I need to mount a updated trim. Is the best option to remove the old housing and put in a remodel can light or is there anyway to add the clips that are in new can light housings? See pictures.
I also have an old Indian trick.
Use two truss head screws on each side, about 1 inch apart. Don't screw them all the way in. Leave them sticking out about 1/4 inch.
Use the space between them for the torsion springsScreenshot_20220303-130430_Chrome.jpg
I would check the diameter of the hole and see if a canless LED wafer will fit. If so, I'd remove the wingnut, pull out the can, and wire the new light with or without the original light's J-box, depending on what I find up there.
Yes, some LED trims come with “friction fit clips” if you have a can that does not have the flanges for spring clips or tabs for standard springs.
Just push the trim up and the friction clips grab the edge of the can.
I agree. Most LED trims have friction clips as standard or at least an option to use them.
