stickboy1375 said:
480sparky said:
Huh? This is what I use:
120/240 Single phase: Black, Red
120/208 Three phase: Black, Red, Blue
480/277 Three phase: Brown, Orange, Yellow
120/240 Single phase: Black, Black :grin:
I hope you don't do black and black on MWBCs
brian john said:
OK B,R,B is pretty much standardized for 208/120, but for 480/277 I have seen every possible configuration, including the use of purple tape. Use a rotation meter and stick with what ever is on that particular job. I have seen electricians argue BOY till there blue in the face changing the job standard and in my opinion possibly complicating future installs.
The year 2008 is about a century too late for my suggestion but I'll give it anyway. . After seeing insulation colors in all kinds of environments, lit with light sources of all different kinds and lighting levels, I believe that
Yellow shows up very similar to
White and should never have been chosen as a phase color. .
Grey in some shades by certain manufacturers in certain lighting, looks almost identical to Brown and should never have been chosen as a neutral color [and some manufacturers Grey looks like a flat Black].
In this part of the country we see:
lower voltage [120v to ground]: Black, Red, Blue with a White neutral
higher voltage [480v phase to phase]: Brown, Orange, Yellow with a Grey neutral
[Pink is common for 3way/4way travelers and of course the Green ground]
I think it should be:
Purple with a
Yellow neutral
and get rid of Grey
completely
[Pink is good for 3way/4way travelers and of course the Green ground]
