peter d
- New England
growler said:Let'm Laugh.
No worries. I was just pointing out how different things are in different parts of the country. Out west, their breaker panels are outside. Talk about weird!
Yep, about half the resi panels I install are outside. And you would have a hard time buying SE cable or anything like it here.peter d said:No worries. I was just pointing out how different things are in different parts of the country. Out west, their breaker panels are outside. Talk about weird!![]()
Davis9 said:http://cableorganizer.com/surface-raceways/wire-guards.htm
Maybe some strategically placed U-Guard?
Tom
I like to use this stuff on the lower side of a meter socket when using SE Cable. When I use it(SE).
Tom:smile:
ishium 80439 said:I'm resigned to the fact that something needs to be done to appease the insp but at this point I just want to tell the HO to have her current "electrician" take care of it (PVC sleeve) and back charge me. I have a feeling that the guy who did the wiring will have that special deer-in-the-headlights look. Perhaps at that point she may realize why we get paid to do what we do.
[why would the current electrician have a deer-in-the-headlights look? /QUOTE]
I'm fairly convinced that it is a homeowners permit with a handyman doing the work. Based on context clues from the HO, the current electrical installer seems intimidated by the concept of playing with the subfeed.
In the long run, after reading comments here, especially those of you who brought up the concept of other people putting their hands on work I still own, I contacted the HO and told her I would protect it. I think I'll try that U-guard. Thank you Davis9. Thanks to everyone who took time to comment.
growler said:In reality I normally run a rigid mast and I probably would have protected this cable with rigid or PVC. Not because it's really necessary but I like for a job to look good and for people to think they are getting a quality product. I like rigid because it's easy to paint to match the siding and it looks solid.
Davis9 said:Good luck with it. I goes in easy anyways. Shouldn't take too long. Make sure you get your inspection right away.
Tom
I always put put SE cables in conduit. It does look much more professional and it will stop the children from knawing on it. Without conduit it realy is just 240 volt extension cord!growler said:I don't think I have ever seen a kid chewing on a service cable. Must be the lead paint, stop useing it.
iaov said:I always put put SE cables in conduit. It does look much more professional and it will stop the children from knawing on it. Without conduit it realy is just 240 volt extension cord!
Its probably the old industrial electrician in me that feels compelled to put everything in conduit.iwire said:I ripped the industrial looking RMC off of my house and installed SE.
IMO it looks much better then the RMC did.
iaov said:Its probably the old industrial electrician in me that feels compelled to put everything in conduit.
cschmid said:I am pipe man I even use pvc instead of UF at my own place.. I use pvc every time I can get away with it it is a cheap as UF and has more options then..
