stucker1101
- michigan
- maintenance
We have an old machine that has no labeling of any kind. All I know is its been fused at the in the cabinet as 480 3ph at 150 amps. The fuses at the Bus Duct are fused at 200amps. The conductors from the Bus Duct are currently #1. My question to the group is more of a thought first. I believe the conductors are too small. The machine in question needs to be considered a continuous load. My questions are simple.
1. Am I on the right path to say that given all other information I should be using 1/O wire?
2. Am I correct in assuming the wire from the Bus Duct to the Machine disconnecting device would be considered a feeder?
Code articles for reference are appreciated....We are still using NEC 2017
Thanks in advance for any help provided
