goldstar
- New Jersey
- Electrical Contractor
This is the second time I've come across a meter enclosure like this one and in the same town. I nearly blew myself up trying to remove the SE cable from the bottom lugs not realizing that they were live with the meter removed. Take a close look at the interior and the jaws. Those two bakalite tabs get pushed in when the meter is installed, the metal strip in the center of the enclosure disconnects the line from the load side jaws and allows the current to run through the meter. When the meter is removed the tabs come out and the power is bussed through to the load side jaws. I had to call the POCO to have the meter ring lock removed. Now I know why they locked it in the first place. If you pull the meter out you get free electricity !!! Has anyone else come across a meter like this ? BTW this is residential not commercial.
