Old Sub-Panel Grounded Thru New Sub-Panel
MrM1
New member
N. Central FL
I am working in an old 60 amp sub-panel in an attached garage wood frame home with crawl space where everything is feed under the house and attached to the floor joists. It is feed from the main load center by 240v (red and black) and a neutral with no ground. All circuits and grounds in this old sub-panel are bonded at this older sub-panel to the neutral.
I am installing a new 30 amp sub-panel with a separate feed also from the main load center in a different location and while doing so have the opportunity (because things are opened up) to run a ground to the old sub-panel. So my question is 3 fold:
1. Would it be idea while things are open to run a ground to the old sub-panel either from the new sub or from the main panel? I would separate the grounds and neutrals in the old panel
2. Can I run this ground from the Newly Installed 30 amp panel. In other words running the ground from the main thru the new panel where ground bonds and then to the old panel (each sub-panel 30 amp and 60 amp both have separate feeds and breakers from the Main - no sharing)? But adding the ground thru the new panel this way would be closer.
3. Just to be certain, regardless if it would be wise to run from the new sub-panel - OR better - a new ground from main panel ... for 60 amps should I a #10 ground? Or can it be #12?
Your thoughts are appreciated.
Mike
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
