I'm curious to know what other contractors are doing in regards to some of the old work problems they come across. My backround is in the industrial area, and I didn't do a lot of residential until I started my contracting business early this year.
I live in NE Ohio, and most of the older homes I deal with are lath and plaster construction. I use Raco old work boxes a lot, the metal ones with the folding sheet metal ears that tighten up against the sides of the box and the plaster. They seem to work well. The problem is that they require an oversized hole to install, and I wonder what others do as far as sealing around the box between the box and plaster. I have thought about latex caulk, but I'm not sure if there's a flammability issue with cured caulk. I've been using patching plaster, but it's very time consuming and messy. Any suggestions?
I've also picked up an assortment of tools that I find indispensible: greenlee long flexible auger bits, pieces of small chain to drop down into walls, 4" hole saws, fiberglass fish sticks, etc. I'm curious to know what other folks feel are great tools. Any info would be much appreciated.
Thanks for the advice.
John
[ November 09, 2005, 06:54 AM: Message edited by: flick ]
John
