chris kennedy
- Miami Fla.
- 60 yr old tool twisting electrician
I'll post a pic in a min, how they come and adjustments need before installation.
Yes, they are, and don't call me Certainly!Certainly the tiger grip is the only solution for masonry walls.
I haven't noticed the device ears being off of 90, but I also adjust the brackets so the back of the bracket is on the same plane as the front of the box.I will add I always remove the top and bottom holding brackets, take my klines and pull the 6/32 ears back to 90? from the face of the box then reinstall the brackets evenly and slightly forward of the face.
I see, said the blind man. Yes, I've noticed that, but it's not usually that severe.I pic 1 note the angle of the 6/32's.
Yep. Makes the entire install look sloppy.In pic 2 note how the bracket that mates with the drywall is set back from the front of the box.
Now, that's a well-tweaked box.This is after tweaking. Makes device and plate installation a snap.
Absolutely. Plastic or metal, the ears interfere with a flush install and plate-to-wall fit.With the old work box I make sure I take off the "Mouse Ears" on the device so the plate fits nice and flush.
Mad bars or 1x5s ws if there is lathe
I don't like any of the options mentioned thus far. Here's a link to a product that seems to be superior in my opinion.
http://www.arlcatalog.com/Fan_Specialty/Steel%20ONE-BOX%20Outlet%20Box.htm
Although I have not personally used this product, I intend to the next time I have an application. Notice it has a 24.0 CI capacity.
They can't be ganged.I see no reason why that Arlington box can't be used for old work applications provided a stud is present.
I agree but I don't think that side bracket could be used very easily.I find it extremely rare that I need to "float" a box for old work. I almost always use the nearest stud. If I were installing a power receptacle, I wouldn't even think about floating a box. I see no reason why that Arlington box can't be used for old work applications provided a stud is present.
Sure have. All the time. If the box is manufactured so the GFI or dimmer doesn't fit, I don't get that brand of wall case again.Have you ever tried installing a GFCI or a dimmer in one of those?
http://www.arlcatalog.com/Fan_Specialty/Steel ONE-BOX Outlet Box.htm
