designer82
- Boston
I have a system with 42 LG400 panels that can output about 15.2kW. The highest Solar Edge inverter seems to output about 11.4kW. Should I put in two Solar Edge 7.6kW inverters?
Is that what's commonly done or is it best to search for a bigger inverter?
Edit: If two inverters is the common way to go, what's the best string configuration...3 strings per inverter with 7 panels per string?
thanks
thanks
