Two underground conduits from the utility transformer run to separate meters on the outside of the building. Then each meter has a run to a 200A main breaker panel. The panels are located in a common mechanical room, either side by side, or directly across from each other.
One panels is house power, the other panel is for tenant power.
Is this considered one service, or two?
Does it matter if the meters are in a common enclosure, or if they are separately mounted side by side?
Steve
Steve
