I need help with grounding. Here is the situation:
Main panel located at a house. The detached garage has a subpanel fed from the main panel. An equipment ground was pulled from the main panel to the subpanel. At the subpanel, should the green screw be used to bond the ground to the enclosure of the panelboard? Also, should the neutral and ground be bonded together?
If there wasn't an equipment ground pulled from the main panel, what would change?
