electricalperson
- massachusetts
what are the pros and cons about an open delta system? is there a way to test to see if you have an open delta system besides looking at the pole?
The advantage is requiring one less transformer.what are the pros and cons about an open delta system?
None that I am aware of, short of asking the POCO.is there a way to test to see if you have an open delta system besides looking at the pole?
There will be 0% less output if the transformer was properly sized as an open delta at the beginning.One less transformer but also about 43% less output.
