According to the NC Building Code (sec 712.3.2 Membrane penetrations, ex.1) when using steel boxes there can be no more than 100s.i. of openings per 100s.f. of wall area. I have been told by several inspectors and an engineer that there can be only one opening per stud space without having to use a fire putty pad. I don't see any limitation in the Code regarding the number of openings in the same cavity. Am I missing something? FYI ... all boxes are opening on the same side of the wall.
