zog said:You want to stand on the hinged side of the cabinet door, not all open the same way, but this rule is a common practice and not found in any US standard.![]()
OSHA bans the wearing of meltable fabrics when arc flash hazard exists but currently does not require arc rated clothing, thats a 70E requirement but is enforceable by OSHA through the general duty clause.
Safety 869, your origianal post mentioned turning your head away, bad idea when wearing HRC 2 PPE, the face sheild turns into an arc scoop in that situation.
If you are standing on the hinged side of cabinet door, in many cases you won't be able to reach the disconnect handle. Also, should there be an arc blast and the door latches do not hold the door will swing into you with great force.:-?
