More a math/physics question, but say you're setting up a portable, adjustable ground mount PV system before dawn for a single day event. So you just want to maximize your solar production over the course of that day, which will be clear all day. Pointing your array due south is clearly optimal, but what is the optimal elevation angle?
A lot of discussions seem to assume that the sun's elevation angle at solar noon is the correct answer, but that can't be exactly true. A little lower has to be better, but is it on the order of 0.5 degrees, or 5 degrees? This must be a solved problem, so I was hoping someone could point me to the solution and save me from looking up the formula for the sun's angle over the course of the day and doing the calculus.
Cheers, Wayne
